Jos_K Posted February 26, 2017 Share Posted February 26, 2017 Hi, When the speakers are placed in standing position I use the folowing setup: Helix > Aux in (rear combo connector) on both L2's Monitor feed from FOH mixer > Mixer in on L2T (set to linked stereo) L2's connected via L6 Link Using the same setup when they are placed sideways, the monitor feed is mono, because the speakers are going into monitor mode. Is there any way to get it stereo without using an external mixer (which would kind of defeat the purpose of the L2T's built in mixer). Thanks! Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 26, 2017 Share Posted February 26, 2017 Have you tried manually resetting the Speaker Mode from Monitor to PA/Reference? I believe you can manually override the default Monitor mode when placing the speaker sideways. The setting button is on the rear panel of the speaker. Quote Link to comment Share on other sites More sharing options...
Jos_K Posted February 27, 2017 Author Share Posted February 27, 2017 Thanks for your reply. With monitor mode, I don't mean the setting on the back. I know you can change that, but from what I've read so far, that's only an EQ correction. Normally when you connect two L2's via L6 Link, one will read R and one will read L in the display on the back. But when you place the L2's on their sides, the display reads B (for both) meaning it will output both the left and right channel. So my question is if that can be overridden. Quote Link to comment Share on other sites More sharing options...
