Fenderflame28 Posted March 9, 2017 Share Posted March 9, 2017 Hi All Just got a second hand HD500x and it's doing something weird. I have followed this video to set up a simple wah/volume: Assigning The Volume and Wah Pedal on POD HDX and POD HD All my settings on the pedal are identical to this. Editor shows the controllers set up as attached. When I hit the EXP toe switch button to change from EXP1 to EXP2 I can hear a change between vol and wah but the actual expression pedal itself has no effect on the sound. When I edit each block on the device, if I turn the knob 'four' I can hear a wah and a volume effect so I know the block is loaded correctly. I have tried using the pre-loaded patches 'son of plexi' and 'spin to win' which both show wah and volume blocks. I can toggle between EXP1 and EXP2 using the EXP toe switch but the expression pedal again has no effect on the sound. Has the unit got a faulty expression pedal or am I being thick? Thanks Quote Link to comment Share on other sites More sharing options...
Fenderflame28 Posted March 9, 2017 Author Share Posted March 9, 2017 Hi Guru Thanks for that - now working fine. :) Quote Link to comment Share on other sites More sharing options...
