soblivion Posted March 15, 2017 Share Posted March 15, 2017 Hi all, Long time Line 6 user, abuser and forum lurker. I usually find most of my answers searching threads that have already been posted. But I have a question that I didn't find anywhere else. I gig on a regular basis and use a POD HD500 and/or HD 500X into FOH and into a powered monitor for stage volume. I love to use the TAP button for time based FX. Anway, I've already had to replace 2 switches that started malfunctioning. I've not had any issues with any other buttons, but I don't ride them like I do the TAP button. What actually happens is when the switch finally gives out it will engage my tuner when I don't want it to(in the middle of a song). I've found this: https://reverb.com/item/806628-one-trick-pony-tap-6-line-6-tap-tempo-controller-footswitch-by-molten-voltage I don't see the POD HD listed as a supported device, but it does say that the MIDI info is MIDI CC 64 value 127, and the POD HD documentation shows this as well. So I'm assuming it'll work. I do have a full MIDI controller, but it seems overkill for a single function. Anybody have any other solutions for an off board TAP button? Thanks, Shawn Quote Link to comment Share on other sites More sharing options...
Mikaere1974 Posted April 1, 2018 Share Posted April 1, 2018 Hey Shawn, I disassembled my HD500 after the warranty had run out and added a 2nd Boss tap tempo via a external jack added to the chassis. Much quieter and more reliable and conveniently placed away from the expression pedal. I can also see the tempo light without my foot covering it. wired in parallel so both switches work individually. Thanks, Michael 1 Quote Link to comment Share on other sites More sharing options...
Mikaere1974 Posted April 1, 2018 Share Posted April 1, 2018 Quote Link to comment Share on other sites More sharing options...
