mousepunk Posted March 31, 2017 Share Posted March 31, 2017 Hello. I use DAW to control my M5 (switching presets). The manual says I can use DAW to control preset parameters with MIDI CC like I use the expression pedal. But how do I assign particular parameter of the preset to be changed with the MIDI CC? With expression pedal you choose the parameter with tweaking it when you plug the pedal in expression input, but I could not find the instruction to choose preset parameter without expression pedal. Anybody tried to do that? It expands M5's possibilities very much, because you can build any additional tone on the basis of 24 existing presets, you can make delay oscillating when it's needed, can change the Whammy's note in real time etc. Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
benjmars91 Posted October 19, 2018 Share Posted October 19, 2018 Hey, did you have any luck with this? I'm trying to figure out exact same thing! Thanks! Quote Link to comment Share on other sites More sharing options...
