musikeren Posted May 18, 2017 Share Posted May 18, 2017 Hi I've just got some IRS, and downloaded them to my Helix LT But when I put them in my chain, there is no sound coming out of the helix.. and when I remove the IR, then the sound is back. Is there a special way to import IRS to the Helix ? Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted May 18, 2017 Share Posted May 18, 2017 On Helix edit, left Column click on "Impulses". Drag your impulses into the slots as wanted. When you place an impulse block, the first parameter allows you to select the impulse you want to use. It defaults to 1 I think but you may have had a blank impulse selected? Not at Helix to verify Quote Link to comment Share on other sites More sharing options...
klangmaler Posted May 18, 2017 Share Posted May 18, 2017 ...and doublecheck the level of the IR block... Quote Link to comment Share on other sites More sharing options...
