laika Posted May 23, 2017 Share Posted May 23, 2017 My amplifi tt has been upgraded to version 2.5, when I connect it to my computer, using cubase for recording time, turn off the cubase monitor button, or will have added the effect of the sound, how can I solve it? When I use it as a sound card, when playing a virtual instrument, it is also noise Thanks My XX has been upgraded to version 2.5, when I connect it to my computer, using cubase for recording time, turn off the cubase monitor button, or will have added the effect of the sound, how can I solve it? When I use it as a sound card, when playing a virtual instrument, it is also noise Quote Link to comment Share on other sites More sharing options...
cloph Posted May 23, 2017 Share Posted May 23, 2017 If you include auto-translation, please include the original language, and not twice the auto-translation :-) I have some trouble understanding what your problem is. But the TT only gives access to the processed sound, you don't get the DI from the guitar for reamping along with it. If you play back from Cubase to the Amplifi using USB, and the sound then is noisy, I assume your levels are too high/you need to reduce the volume to prevent the signal from clipping. But likely didn't get your question - as I also don't understand what you mean with virtual instrument in this context. Quote Link to comment Share on other sites More sharing options...
laika Posted May 24, 2017 Author Share Posted May 24, 2017 thank you for your reply I used amplifi tt as auido interface, ASIO driver selected ASIO amplifi, but when playing any audio, are noisy, I tried to install the 1.64,1.76.1.77 version of the driver, did not solve this problem. Now windows 7 boot when the music sound is noisy, and I use the PC comes with the sound card is not the problem. æ„Ÿè°¢æ‚¨çš„å›žå¤ æˆ‘åœ¨ç”¨amplifi tt作为auido interface时,ASIO驱动选择了ASIO amplifi,但æ’放任何音频时候,都是噪音,我å°è¯•å®‰è£…了1.64,1.76.1.77版本的驱动,都没有解决这个问题。 现在windows 7开机时候的音ä¹å£°éŸ³éƒ½æ˜¯å™ªéŸ³ï¼Œè€Œæˆ‘用PC自带的声å¡å°±æ²¡æœ‰è¿™ä¸ªé—®é¢˜ã€‚ Quote Link to comment Share on other sites More sharing options...
laika Posted May 24, 2017 Author Share Posted May 24, 2017 I have reinstalled windows 7 today And installed a 1.77 driver, but the fault still exists 我今天é‡æ–°å®‰è£…了windows 7 并且安装了1.77的驱动,但是故障ä¾ç„¶å˜åœ¨ Quote Link to comment Share on other sites More sharing options...
