slash755 Posted May 27, 2017 Share Posted May 27, 2017 I am thinking about purchasing one of these for recording purposes. I am running Logic Pro and already have a Mackie Onyx Blackjack interface. Would I be able to run the AMPLIFi TT straight into the interface to record? 1 Quote Link to comment Share on other sites More sharing options...
slimjim57 Posted June 2, 2017 Share Posted June 2, 2017 Yes, a couple of ways. You can run audio out from the mains out to your Mackie. You can also run the USB out directly but I have been having issues with latency using this method. The USB connection basically makes the TT your recording interface instead of the Mackie. So to monitor you either need to use headphones or send the audio to some kind of powered monitor. I found running the audio out from the mains to be the simplest and it didn't give me any latency or tracking alignment issues the way the USB out did. Interestingly the USB out method worked fine with Garageband but not Logic. Quote Link to comment Share on other sites More sharing options...
slimjim57 Posted June 2, 2017 Share Posted June 2, 2017 So if you were thinking of replacing your Mackie with the TT as your main recording interface I wouldn't do it. As a preamp in front of it then sure but I don't know that the amp models and effects are really worth the extra complexity. You still need an iOS device to adjust the tones so now its three devices, the TT, the Mackie, and an iPad. I wish Line 6 would develop a desktop module like Amplitube. Quote Link to comment Share on other sites More sharing options...
yahoomedia Posted February 6, 2019 Share Posted February 6, 2019 Any issues with latency using Amplifi TT with Logic Pro X Quote Link to comment Share on other sites More sharing options...
yahoomedia Posted February 7, 2019 Share Posted February 7, 2019 So far so good with Amplifi TT, Awesome Gadget Quote Link to comment Share on other sites More sharing options...
