How Do I Add Another Path Using Helix Edit
scotsguardsman
I want to add another path for send and return blocks. I know it's simple enough on helix itself just by hitting the action button but does anybody know how to do this on Helix Editor. I've looked and tried everything but I've come to a dead end. Surly this can be done in the editor.
You add Send Return blocks to the signal path using the editor in the same way that you add any other block. Here's a snip from page 9 in the Helix App manual:
To add any type of block to your tone, simply hover your mouse cursor over the desired location on any path and you'll see an empty block location appear.
Once you select the location, choose any type of block from the Model List Menu in the lower portion of the Home panel.
http://line6.com/data/6/0a06439c4dbd577d594db0bd0/application/pdf/Helix%20App%20Pilots%20Guide%20-%20Rev%20B%20-%20English%20.pdf
