SV MKII HD100 Noise at preset change
llabe11
Hello,
I have a problem, I use a pedal MIDI (other than Line6) and change program I hear a POC especially between sound clear and saturated.
Do you have the same problem?
I realized that by increasing the volume of the presets until 11h the noise disappeared but at the same time, it is not possible to play more than 1 on the master of the amp.
Do you have the same problem and have you solved it?
Sincerely
Philippe
Bonjour,
J'ai un problème, j'utilise un pédalier MIDI (autre que Line6) et au changement de programme j'entends un POC surtout entre son clair et son saturé.
Avez vous le même problème?
Je me suis aperçu qu'en augmentant le volume des presets jusqu’à 11h le bruit disparaissait mais, en même temps, il n'est pas possible de jouer à plus de 1 sur le Master de l'ampli.
Avez vous le même problème et l'avez vous solutionné?
Amicalement
Philippe
Yes, I had the same issue. There have been other posts about this in the past. This amp is notoriously loud. Put a physical effect that has a volume setting in the effects loop (preamp out / power amp in). I use an Alesis Nanocompresser and just use the volume only to turn it down. This way I can set the master level to something more reasonable like 4 or 5.
