johnbgooder Posted June 21, 2017 Share Posted June 21, 2017 RESOLVED: Registered the FBV Shortboard Mark ii with Line 6. Downloaded Line 6 Monkey. Flashed the memory back to factory settings and display is back to normal with Amplifi 150. BTW, if you have an external USB hub you may get connection errors (I did). Better to use a USB connection at the PC itself. Initial Post: Hi All, So I bought a used FBV Shortboard Mark ii to use with an Amplifi 150. Worked great for a couple of days but today when I powered up the display was garbage and eventually it crapped out on any settings. I used a different cable and I used the pedal with a Spider Jam and got the same results. Display looks just fine when connected to the computer. Any ideas on what the problem is? Thanks. John Quote Link to comment Share on other sites More sharing options...
