Hopk1ns Posted July 7, 2017 Share Posted July 7, 2017 Is there any way to trigger mixer changes via a footswitch? For example, I may want to toggle between channels A and B being panned hard left/right and both being centred without changing patches. (The only problem with changing patches are the audio glitches, otherwise that would be fine!) Quote Link to comment Share on other sites More sharing options...
J_V_RO Posted July 7, 2017 Share Posted July 7, 2017 Is there any way to trigger mixer changes via a footswitch? For example, I may want to toggle between channels A and B being panned hard left/right and both being centred without changing patches. (The only problem with changing patches are the audio glitches, otherwise that would be fine!) No, but check the volume/pan FX block. Selecting "PAN" you can control L/R channels using the exp pedal. Position matters with this one, try it before or after the mixer block. Quote Link to comment Share on other sites More sharing options...
Hopk1ns Posted July 8, 2017 Author Share Posted July 8, 2017 No, but check the volume/pan FX block. Selecting "PAN" you can control L/R channels using the exp pedal. Position matters with this one, try it before or after the mixer block. Ah, thanks, that works a treat! I can also just set both to pan hard one direction and then toggle them on and off with the same foot switch. Cheers! Quote Link to comment Share on other sites More sharing options...
