bowkore Posted August 7, 2017 Share Posted August 7, 2017 Ive got two pan blocks on different paths, and one set to Left 1 and the other to right 1. When I plug the XLR outputs into the PA's will clicking on the left block for left 1 give sound only to the left XLR output or is it more complicated than that? Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted August 7, 2017 Share Posted August 7, 2017 If you want them to go ALL the way one way or the other and you're using the Pan block, it's Left 100 or Right 100. Keep in mind you don't need to even bother with a pan a block, though. Go to the output block of each chain and there is a pan control. Use that instead. 1 Quote Link to comment Share on other sites More sharing options...
