earth2luna Posted August 18, 2017 Share Posted August 18, 2017 I'm running vocals through some Helix effects. So I'd like to send my mic wet signal out of the xlr output. I'd also like to send a dry signal to monitors to reduce feedback issues. Is this possible? Thanks. Quote Link to comment Share on other sites More sharing options...
yossarian1156 Posted August 18, 2017 Share Posted August 18, 2017 I'm running vocals through some Helix effects. So I'd like to send my mic wet signal out of the xlr output. I'd also like to send a dry signal to monitors to reduce feedback issues. Is this possible? Thanks. Yes, you can do this. You need to create a separate path for your unaffected vocals and set the send to whatever output you want to use. I haven't played around with the send / return, so you might be able to put a send at the beginning of the affected path rather than it's own path, but I'm not sure what happens if you don't get the return. It might kill the signal path completely? Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted August 18, 2017 Share Posted August 18, 2017 You can use a Send without killing the path, so a single send block is all that is needed. Or if in the digital domain USB 8 is the Microphone input direct out pre-everything. DI answers this question in this post and it is elaborated in some following questions and answers: http://line6.com/support/topic/14264-helix-faq/?p=114985 Quote Link to comment Share on other sites More sharing options...
earth2luna Posted August 23, 2017 Author Share Posted August 23, 2017 Thanks for the ideas! I split the path ( one with effects and the other without) and when at the point where they meet again i panned mic 1 out left and mic 2 out right 100% each way. Works great! Quote Link to comment Share on other sites More sharing options...
