gjdjservice2012 Posted August 18, 2017 Share Posted August 18, 2017 Has anyone determined if the channel switching feature (EXT AMP output) of the Helix is compatible with a Friedman Runt 20 amp head? Also, is the Helix supposed to be connected to the Runt 20 channel switching input jack via a TRS cable? 1 Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted November 9, 2017 Share Posted November 9, 2017 Has anyone determined if the channel switching feature (EXT AMP output) of the Helix is compatible with a Friedman Runt 20 amp head? Also, is the Helix supposed to be connected to the Runt 20 channel switching input jack via a TRS cable? Yeah buddy! I tested that last night with my Runt 50; same channel changer as the Runt 20. I set up a Helix patch to use as pedalboard 'only' to the Runt (4 cable method) and then sent the XLR from the Runt back to the Helix, through the Helix looper, and out the XLR / Line6Link to some FRFR speakers. I set up a footswitch to toggle the Runt channel, and also set up that toggle in some snapshots. Sooooooo awesome! No; use a TS cable not TRS for the amp channel changer 1 Quote Link to comment Share on other sites More sharing options...
