Helix firmware update not working
airman2001
I just got the Helix. Has 1.06.5 firmware. Tried to update to 2.21, and it constantly fails. Saying to reboot and try again. So I then tried the reset... 8 and 9 held down while turning on unit. Now... all I get is a small rectangle, inch wide by 3/8 tall scrambled flashing on the screen. Is this normal...will it eventually reset?
I had the same problem.   My helix was defective, I ended up exchanging it for a new one.
My best advice before exchanging it is:
  • Try a different computer (took me 3 different computers before it worked)
  • Try a different usb port
  • try a different usb cord
  • make sure the usb is plugged directly into the motherboard
  • unplug all usb devices except your mouse and the helix and then update (this worked for me)
  • try a manual install, log into the helix in offline mode or use upload a file option.  Download the firmware update from the forums and  then try uploading it with this method
  • make sure you follow the install firmware instructions EXACTLY
Best of luck.
