Sign in to follow this
swordofjustice
Spider V with other Wireless Receivers
G10T systems are auto channel. The unit auto hunts the best channel to use. It's not channel specific where you can set it. G30 can connect like any other amp though, so sure.
Just so I understood you correctly.  I can use my G30 from my guitar and the V60's built in receiver will pick it up?
If the G10T system and the V60 auto-negotiate the channel, would I need to set the G30 to a specific channel since it doesn't autoscan?
I don't think so. You can just use the G30 like you do in any other amp. Once a cable is connected to the Spider Amp, it cuts off the receiver.
You could try to switch channels to see if the G30 is picked up wirelessly. There was a post in the G series area that said one guitar player's G50 was being picked up by the amp (spidr V120) of their other guitarist. They had to start one up first, then the next amp in order for Spider V amp to not pick up the G50
G10T for the Spider V is just the transmitter.
I would think any G10T would work with it if the G10 system bought as stand alone.
Create an account
Register a new account
Sign in
Sign In Now
