kenny382 Posted December 16, 2017 Share Posted December 16, 2017 I have recently bought a second hand vetta1 combo. Fantastic bit of kit but unlike the spider models I had previously I am unable to connect to my PC to download custom tones. The vetta ii appears to connect via USBport however my original vetta i has no USB. I have bought 2 expensive cables that are supposed to connect to PC via the midi port but I have had no luck and my PCs do not see the amp on connection. I am looking to see if there is a site somewhere that has custom tones where I can simply note the settings from the site and manually enter into the amp. Can anyone advise. Thank you Quote Link to comment Share on other sites More sharing options...
zn8ke Posted December 18, 2017 Share Posted December 18, 2017 The Vetta II connects to a computer through MIDI--->USB cables. Doesn't Vetta I have MIDI in/out? I connect my Vetta II with a "M Audio midisport UNO" https://en.audiofanzine.com/midi-interface/m-audio/Midisport-Uno/medias/pictures/a.play,m.424929.html Quote Link to comment Share on other sites More sharing options...
BillBee Posted December 18, 2017 Share Posted December 18, 2017 I use the same cable a Znake. I have to connect it in/in and out/out for an odd reason but it works that way for most stuff. Be sure to get the latest drivers for whatever usb/midi cable you use. There is a really good facebook group for the Vetta where you can probably nab some settings as there are active users there. Quote Link to comment Share on other sites More sharing options...
