garbanzo Posted December 22, 2017 Share Posted December 22, 2017 Hi Guys I run W10, and have had my POD HD connected for ages with no problems. After the most recent update of W10 the PC does not connect to the POD. I have uninistalled and reinstalled Monkey who cleverly notes that I need USB firmware. But I dont know where to download this!! In addition the flash memory and drivers are not found. Several years ago I had similar problems while running W8.1 If I recall I downloaded some files and installed directly, some how going past the Monkey, that is if I recall correctly. In all cases I would be tremendously indebted to anyone who has productive ideas. I should say that my usb port does work, I have checked, and I have run Windows maintance program for checking that all is working correctly which it was. The POD is also working fine when I plug it into my amp, and even my cable is working correctly. Thanks in advance garbanzo ps. Glad Christmas Quote Link to comment Share on other sites More sharing options...
garbanzo Posted January 13, 2018 Author Share Posted January 13, 2018 I should note that this problem was self repaired when W10 completed its latest update. When I turned the pc off the latest downloaded windows material was installed, and when I started the problem was alliviated. This has happened on one additional occasion, for some reason downloaded W10 stuff has an uppsetting effect on the POD. I hope this experience may help others. Quote Link to comment Share on other sites More sharing options...
