bzirngibl Posted January 31, 2018 Share Posted January 31, 2018 Hi all, I have a question on the stereo routing of M9 and if the stereo system could be used as a 2 channel system with 2 separated input and output signals: My signal on my board is splitted with an A/B Box (Little Lehle): Route A= some overdrive pedals and then into the M9 (left/mono input to left/mono output => AMP) to be used with the signal from magnetic pickups on my strat Route B= directly into the MIXER to be used with the piezo signal from my piezo bridge on my Strat My goal is to use the M9 also for my piezo signal: Route B= piezo signal into the M9 (right input => right output) and then into the MIXER) If I understand correctely: with "true stereo" effects the 2 "channels" would be separated as desired. But I am worry about effects with "Stereo Thru/Mono Effect" and "Stereo Thru/Stereo Effect" routing because in my understanding the inputs are routed to both outputs. But I want the signals to be separated completely with any effect of the M9. Do you have ideas to solve this problem? Is there an option to set all FX models to "true stereo" (as many of the delays are anyway)? Cheers Zirni Quote Link to comment Share on other sites More sharing options...
