Looper Input/Output Volume
Johnrichardglock
Is it possible to mute the input going to the Looper so you only hear what is being played back through a separate output?  This would make it easy to send just the playback to a channel of it's own or to send it into another Looper for even more added fun without boosting or changing input levels as well.
In simple terms I only want to hear what is coming out of the Looper through the Looper output not the input and output. This seems be a simple software fix if not.
Thank you very much for you comments and suggestions.
Put the looper on a parallel path with a different output set to that path.
