HX Effects dry routing question
sarlaccmusic
Fresh newbie with the HX, super stoked to dive into this. I admit I'm a little burned out today from hours of failed attempts with firmware updates with my Mac (finally got it using a PC though) so I apologize if I'm missing a tutorial on this question somewhere...
I'll need a mono output at the end, but need to figure out a way to have a dry signal throughout and also blend in my wet effects along the way.
I've messed with the A/B path stuff but I'm missing something and haven't been able to do what I need.
Using this primarily for my sax, so the option of adjusting the mix value within each sound isn't working, so the wet/dry path is really what I'm needing...
Thanks so much for any assistance you folks can offer
Im not familiar with the HXFX interface, but you will have to take one of your existing effects blocks and pull it down to a parallel path. Then put all your effects on the parallel path. You can put a volume control on the parallel path to control the amount of wet in your signal.
