NickWaine Posted February 17, 2018 Share Posted February 17, 2018 Hi, I am using Helix Native with Cubase 9 as a VST3 plugin, and Ableton Live as a VST2 Plugin (Live does not support VST3 instruments yet). I've been experiencing large CPU spikes with Ableton, which I initially put down to a problem with Live's hosting of Helix Native. I've done some further testing, and by removing the VST3 plugin, I've been able to load the VST2 plugin into Cubase. This behaves exactly like the VST2 plugin in Ableton, so it does not look like it's a problem specific to the host. The CPU spikes are causing glitching in the audio, even with a single instance of Helix Native installed, so it's pretty much unusable at the moment as a VST2 plugin. Has anybody else experienced this or have any idea how to get it working? Thanks, Quote Link to comment Share on other sites More sharing options...
soundog Posted February 17, 2018 Share Posted February 17, 2018 The manual infers that the VST3 Helix plug is recommended for Cubase. Are you having spikes with VST3 in Cubase, or just VST2 in Ableton? Quote Link to comment Share on other sites More sharing options...
NickWaine Posted February 17, 2018 Author Share Posted February 17, 2018 VST3 in Cubase works fine, using VST2 in Cubase was just to test if the problem was with Ableton or the vst2 plugin. Quote Link to comment Share on other sites More sharing options...
