elvisvalentine Posted March 2, 2018 Share Posted March 2, 2018 Howdy folks just got me a hxfx and i want to send 2 outputs with different stuff on them to (in this case) a bass amp and a pa. I want my basic bass tone to go to my amp from output L and a ethereal soundscape thing to the PA on output R.This must be possible right? All help greatly appreciated.Cheers. Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 2, 2018 Share Posted March 2, 2018 If you look at pages 31 and 32 of the manual, it talks about setting the outputs for Path B. You could have Path A and B hard panned if that's what you want to do. The other way to do it would be to use one or two of the 1/4" sends as outputs for Path B. If you only wanted to send a mono signal and use the send, you could insert a Send block at the end of Path B. That would mean you could still use a mono effects loop somewhere in your signal path if you wanted. Quote Link to comment Share on other sites More sharing options...
elvisvalentine Posted March 2, 2018 Author Share Posted March 2, 2018 Thanks for the reply,Hard panned is fine, i am unable to get it working on my hx though. I don't know where i'm going wrong. Quote Link to comment Share on other sites More sharing options...
