dacu1 Posted April 4, 2018 Share Posted April 4, 2018 I want to use the power over ethernet port of a Flextone I amp to power a Relay G10: Flextone --> ethernet cable --> adapter (like this) --> Relay G10 Receiver. Has anyone tried this successfully, and, if so, with what adapter? Am I right that the Flextone ethernet port is POE? I can't fine any specs on the power output. Quote Link to comment Share on other sites More sharing options...
dacu1 Posted April 8, 2018 Author Share Posted April 8, 2018 Well, I guess I'll answer my own question. Found this page: http://www.harmonicappliances.com/floorboard/floorboard.html which describes the pin-out of the Line6 Floor Board RJ45 port (compatible with the Flextone I). Assuming the author is correct, a regular POE data/power splitter wouldn't work, because the Flextone output voltage is not what a splitter would expect, and the pins are in the wrong place. Quote Link to comment Share on other sites More sharing options...
