Amplifi 150 amp. Looper pedal setup?
I'd like to use a looper pedal with my Amplifi 150 amp and MKii Shortboard.  Seems I could place the pedal between guitar & amp, but each looped layer will will have no amp affects. I'd like to loop so each looped layer could have different affects.  Any way to accomplish this with an add-on looper pedal just using the amp or some other means,  without buying a bunch of added pedals to put before the looper & Amplifi amp. Thanks in advance for any shared info.
Edited by jbyrnez
  • 2 weeks later...
Unfortunately, since all the amp and effect modeling takes place in Amplifi, and there is no effects loop, you won't be able to use a looper pedal in front of Amplifi and get the desired results of effected tones in the loop.
