misara20 Posted July 4, 2018 Share Posted July 4, 2018 Having issues with the M9. Tempo is not maxing out to change to notes so I can use the tap tempo. I have also checked in the setup to change the pots ABS/REL but there is no settings found in the setup screen as shown on the picture. Quote Link to comment Share on other sites More sharing options...
Tampei Posted April 13, 2020 Share Posted April 13, 2020 same problem, did you solve it? Quote Link to comment Share on other sites More sharing options...
drewharris Posted August 5, 2021 Share Posted August 5, 2021 I had to the same thing happen and managed to fix it myself -- it appears to most likely have been dirt built up on the pot. I opened the unit up, disconnected the ribbons cables and removed the PCB's til I got to the user control card. The pot looks like it's sealed, so I didn't make any attempts with contact cleaner/lubricant, but I did take a toothpick and scrape clean all around the perimeter and flat portion of the plastic moveable knob where it goes into the metal housing -- a decent bit of gunk and grime had built up here over time. Put the cards back in, reseated the ribbon cables, and voila -- it worked correctly again. Quote Link to comment Share on other sites More sharing options...
