New Looping Function 2.6 ?
JLondon
On 7/11/2018 at 3:23 AM, sudiptasingh said:
Pressing and holding to clear the loop plays the 1st second of audio. Is there a CC message that we can assign to another switch to clear the loop in memory?
I've requested this, no joy so far. It's infuriating live, so I've added an external mute switch to engage whist deleting - the HX doesn't have enough blocks for me to add this as an internal switch. Any easy fix to use midi, long overdue!
  • 2 months later...
I play in a blues band where there is only one guitar player ( it's me! ). By this way I use a lot the 6 button looper in HX effects. I use the HX effects in snapshot mode. However it started to get crazy in live performance because of making a lot of step dancing to go in/out the looper. So I decided to buy an Boss RC1 in order to make it easier to access the "looper" function of my pedal board. But... you know... A Boss RC1 it's not the same thing as the HX effects 6 button looper. And does not make sense to spend money in a very expensive external looper to do the same job of HX effects looper just because the HX effects looper is not easy to use.
Today I wrote to line 6 to make a recomendation in order to make this product even better.
I asked line6 to allow to use the PEDAL/EXT AMP to make the HX effects go in/out of the its looper module. So, a single switch connected to PEDAL/EXT AMP could do the job and it would be amazing!
From my understanding it is only a firmware change that is needed to put it working.
Let's wait for line6 answer.
