VirtualGuitars Posted August 15, 2018 Share Posted August 15, 2018 Hi, I've asked this before, but I can't remember the answer. I have two Marshall amps that I use with the 7CM. Unlike the HX Effects, the Helix only has one Ext Amp jack and I would like the ability to switch channels on both amps simultaneously. Both Marshall amps use the same configuration on the Helix for channel changes, so I'm looking for a way to split that into two TS connections. What 3rd-party splitter can I use to make this work? Will a simple TRS Y-cable work? Thank you. Quote Link to comment Share on other sites More sharing options...
