Powercab Plus/Helix - How To MIDI Question
mikej555
I am having difficulty getting Powercab Plus to work properly with MIDI commands sent from Helix. I have tried two methods 1) using MIDI CC Commands and 2) using Bank/Program Commands. I have seen the thread and video at topic/34848-attempting-to-use-midi-to-switch-speakers/, while informative, I was not able to solve the problem. Same for topic/34061-helix-lt-in-powercab-via-midi-not-working/.
Hookups:
 L6 Link (for audio) Helix > Powercab
 MIDI (send commands) Helix > Powercab
 USB (Powercab Edit) Computer > Powercab
Settings:
On Helix (firmware 2.60)  Menu > Global Settings > MIDI/Tempo. Receive MIDI Clock = AUTO. Send MIDI Clock = OFF.
On Powercab (firmware 1.01)  Menu > Global Settings. MIDI PC Receive = ON. MIDI PC Send = OFF.
Regardless of method used:
Helix preset 01A = Flat Mode.
Helix preset 01B = Speaker Mode, Vintage Model.
Helix preset 01C = Speaker Mode, Green Model.
Clearly a MIDI command is being sent, but the results are completely wrong. What is a bit weird about this (probably not a coincidence) is that Helix preset # is somehow synced with the PC preset #. Even when I swap patches around Helix 01A = PC preset 1. I suspect/hope it is something simple. Maybe a rookie mistake in my setup. I just got the Powercab yesterday.
Thanks Mike
Extra Data
The MIDI cable is same one I used to send MIDI changes to my DT Amp, so I am sure it works fine.
Attempt using Bank/Program Commands:
 MIDI Channel (leave at Base)
 Bank CC00 (leave at Off)
 Bank CC32 (leave at Off)
 Program (set to preset #)
   Helix preset 01A set to PC preset 2
   Helix preset 01B set to PC preset 2
   Helix preset 01C set to PC preset 1
Attempt using MIDI CC Commands:
 Helix Preset 01A
   CC #   Value   Should Be Result
   20      1      Set Speaker Mode
   22      1      Set Green Model
   23      0      Set 57 Dynamic
 Helix Preset 01B
   23      1      Set 409 Dynamic
 Helix Preset 01C
  22      0      Set Vintage Model
  23      2      Set 421 Dynamic
I figure some of it out. Rookie mistake. Sending MIDI Commands using Bank/Program Commands works as long as the Powercab Edit software is not open at same time Helix is sending commands. It must set up a conflict of some sort.
I am still not able to get it to work using MIDI CC Commands -- even with Powercab Edit software closed. I am still interested in ideas on making that function work. If it were designed to only take presets via  Bank/Program Commands why would Line 6 give us all the MIDI CC Values in the user manual?
Thanks Mike.
  • 4 months later...
I've spent a couple of hours trying to get my LT to change to specific speaker combinations on the PC+ (NOT presets) and finally the only way I've got it working is to follow the method used to make the LT choose a PC+ preset, program that in command centre as a 'Bank/Program' command, and then do a seperate 'CC' command after it.
For example
Command 1 sets a bank command to change to preset '0' on the PC+ (the 'flat' mode) (see attached image)
Command 2 sets a CC command to change preset voicing to '1' (the 'fl solo' mode) (see attached image)
I was unable to get this to work using only CC commands.
I hope this helps someone out there as there isn't much information online (apart from a couple of useful youtube videos and a post on this forum) but for some reason I still couldn't get it working until I tried to combine bank and CC commands, which I hadn't seen anyone suggest before.
  • 2 months later...
  • 6 years later...
