AcidRonin Posted August 23, 2018 Share Posted August 23, 2018 So I have a Pod HD Pro X, and I use it as a USB plugin audio interface. Recently I have been having all sorts of system stability problems while having it plugged in. Everything is fully updated, is anyone else having this issue? Quote Link to comment Share on other sites More sharing options...
joel_brown Posted August 23, 2018 Share Posted August 23, 2018 Also other drivers such as ASIO4ALL.sys will cause problems when used in conjunction with Line6 drivers. Quote Link to comment Share on other sites More sharing options...
WarringtonCJ Posted August 28, 2018 Share Posted August 28, 2018 This happens to me with all kinds of gear due to ASIO. If i'm in Reaper with my Behringer XAIR selected as my I/O and I unplug it without exiting reaper first I'll blue screen every time. Whatever DAW you're running make sure you exit that first or change your I/O before removing the USB, just to be safe make sure you exit Pod HD Edit before disconnecting as well. Quote Link to comment Share on other sites More sharing options...
akeating Posted August 31, 2018 Share Posted August 31, 2018 I have had the same issue in Windows 10. The problem seems to be the Windows OS trying to default to the regular audio drivers in the computer. You need to disable and disconnect the Windows audio drivers and just run everything through your Line 6. When there are two line 6 drivers competing, you can only use one at a time, or the blue screen will appear. It is a Windows problem, not a line 6 problem. Quote Link to comment Share on other sites More sharing options...
ColinWise Posted February 13, 2024 Share Posted February 13, 2024 I know this is an old post but. Windows 10. This is what worked for me ! I had the blue screen when I closed gearbox(every time). I found that if I made sure the pc sound setting was set to "speakers(realtek High Definition Audio(SST))" By clicking the speaker icon ,bottom right and selecting it from the list. My blue screen issue when closing gearbox was in the past . Quote Link to comment Share on other sites More sharing options...
