saving parameter changes in snapshots
axell02
Can't save parameter changes on distortion block from snapshot 3 to 4. I've changed global settings from "recall" to discard" and neither works. I know the easy fix is to just add another distortion block and call it a day but I shouldn't have too !! Can anyone please help. Thanks, Rob
In order for parameter values to be recalled via snapshots, those parameters have to be assigned to controllers. If you only want to control it with snapshots and not a real-time controller like an expression pedal or footswitch, you can just assign them to a Snapshot Controller. On the unit itself, simply press and turn the knob under the parameter. Once you do that, you'll see brackets appear around the value. Now you can save unique values for that parameter per snapshot.
  • Thanks 1
