shemeshg Posted September 18, 2018 Share Posted September 18, 2018 Do for example this simple test, 1. set preset to "factory 2 - 01A Boutique", -> this is a Dry/Wet most simple straight forward example 2. on your DAW, set your monitoring to Pre-Fader to see level indication Unexpected Result ->. when Volume pedal on Wet Position (100%) Left right are balanced when Volume pedal on Dry Position (0%) [no sound routed through the Delay] Left is 5db more then the right. Quote Link to comment Share on other sites More sharing options...
shemeshg Posted September 21, 2018 Author Share Posted September 21, 2018 found that it has in the preset file "join" : { "@model" : "HD2_AppDSPFlowJoin", "B Pan" : 0.85000002384185791, "B Level" : 0, "A Level" : 0, "A Pan" : 0.14999997615814209, "@position" : 8, "Level" : 0, "@enabled" : true, "B Polarity" : false }, Since it was a preset for me, i never looked closely into the join, setting the panning at the join solved it Quote Link to comment Share on other sites More sharing options...
