evh5150combo Posted November 1, 2013 Share Posted November 1, 2013 Hi everybody, i have a pod hd500 connected to peavey 5150 using 4 cm and I'm really satisfied. I'm also using 5150 with a thd hotplate. Now I would like to build a wet/dry setup, usign the line out from the thd hotplate and feeding the path B of the pod, while in the path A i still use the FX loop setup. But every time I connect the Line Out to the Aux input of the pod , I get a tremendous feedback. Is it possible to have 2 really independent signal paths?? Quote Link to comment Share on other sites More sharing options...
GTLazer Posted November 1, 2013 Share Posted November 1, 2013 Check your mixer settings. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 1, 2013 Share Posted November 1, 2013 Try this sample preset: http://line6.com/customtone/tone/217206 Quote Link to comment Share on other sites More sharing options...
evh5150combo Posted November 1, 2013 Author Share Posted November 1, 2013 Thank you. I found the solution. It was a problem of ground. When you use the line out of a THD Hotplate you have to use a guitar cable with no ground. Now I've got another problem:I've noticed that when I put the fx loop signal in channel A, I have a significant increase in Gain. My mixer is channel A panned Left, and channel B panned right, mixer levels at 0. Have you noticed the same problem?? Quote Link to comment Share on other sites More sharing options...
