sarlacc
volume drops in half
at my last gig my amp (spider IV 75w) would occasionally drop the volume down in half. when hitting any button on my fbv shortboard the volume would return back to normal. any ideas what may be causing this?
Check the pedal calibration on the shortboard?  Try to repeat the behavior at home without the shortboard plugged in to determine if its the amp or not causing the problem.
i did calibrate the shortboard and also downloaded the latest firmware for the amp as well.  i played it for about an hour or so and it didnt drop the volume at all. 2 gigs this weekend will be the test though. thanks for your response...
