Papanate Posted October 1, 2018 Share Posted October 1, 2018 I figured it out from a post here on the forum! The short story - instead of using CC information like you would do normally change the parameter to Automation and choose a 'Knob'. Then go to Logic Pro X - 'Controller Assignments'/'Learn' and push the pedal down and up. The Knob will be learned - and now I have control over the Wah Wah. I repeated the same for Volume control - took it from CC #7 and changed it to Knob #10, Repeated the Learn Assignment - and Voila - I now have Volume control as well. Weird work around - but it works fine. I've been scratching my head for two days trying to get Helix Native as a plugin in Logic Pro x to recognize the expression pedals on my Behringer FCB 1010 pedal board. I'm using a 2018 MacBook Pro - High Sierra - Logic Pro X - Appogee Duet USB and a mio iConnect Midi Din to USB to connect to the laptop. Background info: I have a midi utility that shows me midi messages being sent, channels etc... I set the Expression Pedals on the FCB1010 to CC 20 (for a Wah) and CC 7 (For Volume). Using Logics built in pedal board Wah - I can easy assign CC 20 to control the Wah and I'm done. In Helix I've set the Wah Pedal to CC 20 - and I get nothing. Midi Utility shows the messages being sent. Current Predicament I created a MainStage file - using the Helix Native as a plug in. MainStage shows my CC numbers and the pedal travel just fine. I can physically see the expression pedals going from 0 to 127. Helix Native still can't. I'm not married to the FCB (I've had it for a while and it cost very little). Trouble is I see nothing out that acts as a control pedal board in Helix Native - well barring buying the Helix LT - which is a bit pointless becuase I bought Native so as to not spend $1K. Anyone with a solution or answer? 1 Quote Link to comment Share on other sites More sharing options...
