RandomGecko Posted October 9, 2018 Share Posted October 9, 2018 If I have my HX hooked up in stereo to a pedalboard junction box/interface, but only run into one amp, if I only hear the left side, is that the same as running in mono, or is the mono usually a summed signal? Obviously if you run in mono as per any "normal" setup, say using the FX loop of an amp, and you set run a stereo delay, it sums that, but if you run a mono delay, come out of the HX in stereo, but only use say the left side, is that half a signal or is it sending an equally strong signal down both channels... if that makes sense? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
