HX Stomp only—Shortcut: Press ACTION andPreferences > Snapshot Edits value
amsdenj
This is in the release notes for HX Stomp 2.70.0: HX Stomp only—Shortcut: Press ACTION andPreferences > Snapshot Edits value.
Looks like this is missing some text and should be:
HX Stomp only—Shortcut: Press ACTION and <PAGE to quickly switch Preferences > Snapshot Edit behavior between RECALL (gray) and DISCARD (red).
This makes it easier to edit and save different snapshots. When performing, you generally want Snapshot Edit behavior to be set to DISCARD so that when you switch from snapshot to snapshot, you go to what was last saved, a predictable, consistent setting. However when editing snapshots, it is convenient to switch to RECALL so that you can change parameters in any snapshot, switch to the snapshot that should be selected when the patch is selected, press ACTION+<PAGE to switch back to DISCARD, and then press SAVE only once to save all the snapshot updates.
