pott24 Posted October 27, 2018 Share Posted October 27, 2018 I've not tried it yet on a Midi controller, but on HX Edit you can assign a Bypass control to FS4/5 even without anything plugged into the external controller input. This opens-up possibilities: I could plug my Boss FS7 into my MC6 to add a dedicated FS4/5 footswitch which would work on all Presets! With the free external controller input, I can now also use an expression pedal. Is anyone running their Helix Stomp this way? Am I correct in my assumptions? EDIT: this does not appear to work as desired with a Boss FS7, which only gets recognized as an expression pedal. More digging is needed... I THINK it may be because I only have a TRS->TRS cable for the FS7, while in this case I'd likely need two mono cables or a TRS->Mono x 2 cable. EDIT2: yes, using two simple patch cables from FS7 to MC6 enables both of the Boss units' footswitches. BUT... the MC6 still thinks they're expression pedals, and effects are only triggered momentarily; likely they're not the right type of switches to work with the MC6. Shame. EDIT3: I got an auxiliary switch from AmericanLoopers: https://reverb.com/item/7006147-aux-switch-for-morningstar-mc6-side-jack-three-click-less-buttons. This will be dedicated Tuner + FS4 + FS5, and I will also plug in the expression pedal (a Moog EP3) into the MC6. I could still use the Boss FS7 into the HX to be fair, and the Expression pedal through the MC6. To try this weekend. Quote Link to comment Share on other sites More sharing options...
