feffa86 Posted October 31, 2018 Share Posted October 31, 2018 I start up Reason, load up a new audio track, then add Helix Native as an effect. It loads some preset by default, with a few EQ and dynamics blocks or something, because the sound of my guitar changes when I add Helix Native as an effect. When I click to open the Helix Native UI, the VST crashes however. So it definitely goes up and running, but doesn't let me open the UI. I am using a Scarlett Focusrite 18i8 1st gen and it is set to be my audio device when I try this. I have tried going into Windows settings and changing to the onboard soundcard, as well as the Helix ASIO driver, and it happens regardless. Reason is up to date, the driver to my Scarlett is up to date, my Helix Edit and Update and drivers are up to date, and my Helix Native is up to date. (2.70/1.70) So to stress that, I am able to load the VST plugin, and it loads fine, and it does affect the signal (meaning the VST runs initially after I load it). But If I try to actually open the Helix Native UI to add more blocks or whatever, it crashes and tells me to restart Reason. Clues?? Quote Link to comment Share on other sites More sharing options...
benvigil Posted November 12, 2018 Share Posted November 12, 2018 There are a number of threads about Native crashing various DAWs on both macOS and Windows. I don't want to be spamming threads, but as a Windows user you should look at: Quote Link to comment Share on other sites More sharing options...
