wherermykeys Posted November 23, 2018 Share Posted November 23, 2018 Just picked up a V30 and I'm trying to "normalize" all the volume setting across the presets I use. I've saved a few into bank 32. I can edit and save all the other settings except for volume. As soon as I switch to another preset and switch back, the volume goes right back to where it was. I've tried doing a factory reset already. Quote Link to comment Share on other sites More sharing options...
thorneven Posted November 26, 2018 Share Posted November 26, 2018 If you'll explain what state your amp is in (what is displayed on the amp and LCD screen) when you save settings and where you are adjusting the volume that isn't being saved, maybe we can help you better. Thorne Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted November 28, 2018 Share Posted November 28, 2018 You are trying to save the channel volume, not the master volume, correct? Quote Link to comment Share on other sites More sharing options...
wherermykeys Posted November 28, 2018 Author Share Posted November 28, 2018 Yes I’m trying to save the channel volume. I’ve figured it out though. For some reason, it will save if I adjust the channel volume using the actual volume knob. But if I try and adjust it while in the edit screen using the rotary knob, it won’t save. 1 Quote Link to comment Share on other sites More sharing options...
