NebWeb Posted December 4, 2018 Share Posted December 4, 2018 When I choose a patch, then double click the 'amp' foot switch, and start turning the selector knob, different amps load. 1) The amps load with their virtual pots in certain positions (some of them in very weird positions). Can anyone clarify that this is either the factory default setting or a user-saved custom setting? 2) The virtual pots have dots around the outside. Can anyone confirm that these dots are the last settings that I used for this amp model when saving it in another patch? The manual is not clear on this point. Further, if the previous owner has saved a custom amp setting over the factory default, is there a way to tell which amps have been altered by the user? Is there a way of getting an amp setting back to the factory default? Thanks. Quote Link to comment Share on other sites More sharing options...
daveny5 Posted December 4, 2018 Share Posted December 4, 2018 The dot tells you where the knob was set the last time it was saved. There is no way to know if that's the factory setting or a user setting. To reset to factory setting, read this link: Quote Link to comment Share on other sites More sharing options...
NebWeb Posted December 5, 2018 Author Share Posted December 5, 2018 So basically, once you've saved over an amp preset, it's gone. I can't factory reset the unit, because I'll lose the metal shop add-on that a previous owner put on it. Thanks for the confirmation. > The dot tells you where the knob was set the last time it was saved [in a patch] OK, so an amp loads into a patch with either a factory setting or a saved custom setting. The dots show the setting of the amp when it was last saved in another patch. Thanks. Quote Link to comment Share on other sites More sharing options...
