KCPC_Gtr Posted December 9, 2018 Share Posted December 9, 2018 Hi trying to get the few block to assign to the switches so that I can turn on and off while I play. ..just cant seem to do it right? Please help. Manual said.. Bypassing a Block 1. If not already there, press VIEW to select Edit view. 2. Turn the Upper Knob to select a block and then press it to tog- gle the block on and off. A bypassed block appears semi-transparent and, if assigned to a Stomp mode footswitch, its LED ring dims: But. I can't seem to nail it.. Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted December 9, 2018 Share Posted December 9, 2018 9 minutes ago, Guitarsarang said: Hi trying to get the few block to assign to the switches so that I can turn on and off while I play. ..just cant seem to do it right? Please help. Are you in Stomp mode (one of four modes on the Stomp ... found by hitting "home" and then page right or left until you get to it - you know you're there if when on a preset let's you use the stomp switches for effects). Once there, select the effect you want. Then rest your finger on the switch you want to attach it to. The screen will change and ask if you want to assign the foot switch. Press the circular button underneath the green "ok." Did you watch Line 6's basic tutorial videos on YouTube? They help a ton. 1 Quote Link to comment Share on other sites More sharing options...
KCPC_Gtr Posted December 11, 2018 Author Share Posted December 11, 2018 Got it to work.. thanks.!!! Quote Link to comment Share on other sites More sharing options...
