Monsta-Tone Posted December 30, 2018 Share Posted December 30, 2018 I have a Helix Floor. I have the built in Expression Pedal set up to toggle between Wah and Volume when I press the Toe Switch. I also have a Helix Rack (thank you my lovely wife for the Christmas present!) and Floor Control. I have a Mission Expression Pedal with Toe Switch that I plugged into EXP 1 and Toe Switch on the Floor Controller. I was wondering why it didn't work like the Helix Floor's Expression Pedal........ Then, the little candle came on over my head......Helix Floor's Expression Pedal is set up as Expression 2 when the Toe Switch is pressed....... Is there any way with the Helix Rack to use a single Expression Pedal in the same way as I have the Helix Floor set up? Also, from what I have read, there is no way to calibrate the external Expression Pedal. Is this still true with Firmware 2.71? Any help will be eternally appreciated. Quote Link to comment Share on other sites More sharing options...
Monsta-Tone Posted December 30, 2018 Author Share Posted December 30, 2018 I just noticed that Mission has a specific Helix Expression Pedal. https://missionengineering.com/shop-2/products/expression/specific-use-exp/sp1-l6h/ My Expression Pedal has a 100K Linear Pot, and a Latching Switch. The Helix Expression Pedal has a 10K Linear Pot and a Momentary Switch. Guess I should pick one up and see if it works like I want it to. Does anyone here have experience with the Mission/Helix Expression Pedal and toggling between the Volume Pedal and Wah Pedal with the Toe Switch? Quote Link to comment Share on other sites More sharing options...
