modelation 7 Posted January 5, 2019 This may have been discussed before and I missed it (sorry) ,,,, It looks like using an IR only in the Powercab is the same as using an IR only in the Helix but with the IR as the last block in the signal chain. This seems non ideal as the optimal signal chain would be something like Amp->IR(cab)->Reverb->Delay. Using an IR in the Powercab, this would be Amp->Reverb->Delay->IR(cab). Does it make sense to use two IRs: Amp->IR(cab)->Reverb->Delay->IR(PC)? Has anyone done a comparisons between these signal chains? Maybe there is not much difference? Two IRs in series of course could be problematic. Quote Share this post Link to post Share on other sites
dgothard 2 Posted January 19, 2019 To me using the Cab or IR last emulates more of how a real amp would operate where you have PreAmp->FX Loop (Delays & Reverbs)->Poweramp->Speaker vs how you would operate to do recording by having a Cab then applying delays, reverbs like you might do with a mic'ed amp into a DAW. Either way is not wrong just different. Quote Share this post Link to post Share on other sites
modelation 7 Posted January 20, 2019 I agree that this is much like a typical amp with FX loop setup. But an ideal setup would be like a concert hall where the delay and reverb would come after the speaker cab IR. Probably doesn't make much difference though. Quote Share this post Link to post Share on other sites
amsdenj 586 Posted January 20, 2019 Since convolution is linear, it probably doesn't make much difference for most effects like EQ, reverb, delay, modulation or other linear effects that might typically go after the amp in a live or recording situation. However, compression would be different. Since convolution is a linear time varying system, the compressor input would see different signals depending on whether it was before or after an IR block. This is similar to the discussion about EQ before and/or after compression. Both are valid and do different things. However, if the block is non-linear, than positioning before or after the IR block could make quite a difference. But typically we wouldn't put distortion or amp blocks after an IR. Quote Share this post Link to post Share on other sites
