Andybassdoyle Posted January 14, 2019 Share Posted January 14, 2019 Looking for some guidance please - I'm trying to configure a footswitch to send midi cc changes to a future impact synth to change patches. No joy despite having set the correct channel and instruction via the command centre. What I do notice is that the helix is sending patch change info when I change presets. I'm new to this and the presets were already loaded so be gentle and assume I am a total idiot! Thanks Abd Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 14, 2019 Share Posted January 14, 2019 Patch changes are made using PC#s, not CC#s. Depending on the synth, you may also need to send Bank Change (MSB) messages. To prevent the Helix from sending default PCs, in Global Settings-MIDI/Tempo, change the MIDI PC SEND setting to OFF. Then use Command Center to assign custom Bank and Program Change messages to Instant Commands to send what you want when you load Helix Presets. Quote Link to comment Share on other sites More sharing options...
