pboy76 Posted November 22, 2013 Share Posted November 22, 2013 Hi, I have a variax 700 acoustic, powered by xps A/b box. Now, the 9v AC 2000mA power supply used for xps doesn't work, and I would like to change it. The xps needs 2000 mA to work, or I can use another power supply with handle less mA (such as some power supply like Cioks AC Rider, T-Rex Fuel Tank Goliath...)? Thank you Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted November 22, 2013 Share Posted November 22, 2013 One thing that is unique about these power supplies is that they are AC. If you replace it make sure the replacement is also AC! I do not believe that you need 2000mA for the Variax. Half that should be fine based on the battery run time. DO NOT USE A DC POWER SUPPLY! Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted November 22, 2013 Share Posted November 22, 2013 best to do a quick web search and get the original power supply... very common search for line6 PX2 Quote Link to comment Share on other sites More sharing options...
pboy76 Posted November 22, 2013 Author Share Posted November 22, 2013 Thank you for your replies. I know that AC is the most important element, but I would like to know if there are another methods to powering xps. Some power supplies provide 9ac current (cioks AC rider, t-rex fuel tank goliath), but with less mA, so I don't sure that xps works properly. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted November 22, 2013 Share Posted November 22, 2013 I think the reason they ship a 2000mA AC supply with the XPS is because they use that supply for many of the pods. I know for sure that the XPS / Variax doesn't use anywhere new 2 amps. If you have a 9VAC supply that is good for 1 amp (1000Ma) that will work. Quote Link to comment Share on other sites More sharing options...
