Firehawk FX Master Tempo?
peecemaker93
I’m trying to set up my Firehawk to run different amp settings instead of running drive/gain pedals but I’m running into the issue when I switch between presets, the tempos are different. Is there a way to set the Tap Tempo to be a master or global tempo that sets it for all the presets at once so there is not a tempo difference between, say preset A and preset B?
Thanks in advance!
Unfortunately, no. Tap temps are based on the individual block you choose and reside solely in the preset.
What I would suggest doing is create your initial preset and save it as is with the tap temp you like, and then save that same preset in a new slot. This should copy the tap tempo you had into the new preset. Then you would change the preset to how you like it and update the save.
Once you're ready for your third preset do the same thing as before, and so on.
