Sign in to follow this
runner1000
flash memory
You'd have to connect to it via MIDI and use the DTedit to find out what firmware.
  • Thanks 1
You have to use Line 6 Monkey first, especially if it isn't at 2.0 and you want to update it. DT Edit will not update the firmware -
Where can i find DTedit? I need to know what firmware my DT25 is running on. It's now working with the new Helix 2.80 or 2.81 updates and the Monkey is not recognizing the DT25.
DT Edit is pinned on the top of this forum. If Monkey is not recognizing the DT25 it's possible using DT Edit might show the same results not seeing the DT25
Jd
