wersonnst Posted December 8, 2013 Share Posted December 8, 2013 Hello all, I've done all my Musik with an Linux system (this time LMDE) and Jack. I hope there will be an linux driver for the M20d. I use the M20d for live performance and to record the inputs. Because of our life Stages (mostly churches) Monitors and PA the main out is useless for an CD or to give away. It's very nice to make an mix of the recordings on the M20d that sounds great for every one. To save the main mix I want to use the main out via USB but I found no driver for my Linux Studio. Or is it possible to save the main output to USB Disk. Is there an chance to get it working on Linux systems , maybe with wine and wineasio? Regards Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted December 8, 2013 Share Posted December 8, 2013 Record to the SD Card using the built in features then import into your Linux workstation? Quote Link to comment Share on other sites More sharing options...
wersonnst Posted December 11, 2013 Author Share Posted December 11, 2013 That is the way i do it this Time but Not the Way it should be done. The Software is mostly Based on Unix Code. But the asio driver is not compiled for Linux. Please make one. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted December 12, 2013 Share Posted December 12, 2013 it's not an audio interface... if you look over the forums you will find many unhappy users that tried to do this.. with supported drivers... you're doing it the best way right now. Quote Link to comment Share on other sites More sharing options...
