Pedal PCB for Pod XT Live Needed
Hi, I'm trying to source a Pedal PCB for my PodXT Live. The pedal function has died - both Volume and Wah, and I've reset software/firmware and updated all drivers and flash mem, pretty sure its either the light emitting diode or the opto-transistor on this PCB that is faulty, so need to swap the PCB. Part number is 50-02-0032. Does anyone know where parts can be obtained or perhaps someone is breaking one for spares ?? I'm attaching a picture of the PCB
Thanks
LesM
  • 5 years later...
Dammit. I've had to disconnect the pedal because there was a problem where the output of the pedal would cause the volume (or wah or whatever parameter was assigned to the pedal) to jitter almost like a fast sample and hold on a synth. I came here hoping Line 6 would offer a replacement but I see this post has been ignored for six years. Sigh.
I did find a way to point the pedal output to an unused parameter (something to do with the cab sims, as I plug into my amp) and use an external pedal for wah or whammy if I wanted, this might be of use to someone else who has the same problem but can't find a replacement part. I ended up just unplugging the ribbon cable as I barely used those features. But it would be nice if there were a solution.
